i have a 1997 ez go dcs i have replaced solenoin and controller cart runs fine the problem i have is the reverse buzzer goes off when cart is sitting key is off cart is in neutral parking brake is locked and it starts buzzing please help thanks
unplug your limit switch on the foward and reverse handle and see what happens the spring tension may be loose on the switch and the least movement will make the connection and buzzer will start just guessing but a simple place to start.
