1996 EZGO TXT 36v Won’t Run
Matt mm
I’ve got a 1996 EZGO TXT 36v that I’ve put a new ITS sensor, new forward reverse switch, new controller and new solenoid and it still won’t run, it just clicks at the solenoid. I did the test on the motor and it runs. I’ve got power at the motor but it won’t go. Any ideas?
Bhwitcher
Have you downloaded the 1996 E-Z-Go Text Service manual? It has a great troubleshooting section that you can use with a multimeter to diagnose.
I have the same cart but my solenoid is not clicking, so I am running down the list now.
Bhwitcher
Any chance you could take a picture of your solenoid? I’m a bit confused as to the direction of the solenoid. The old solenoid that I removed had the lip on top and terminals closer to the top but when I received replacement it was labeled the opposite direction with lip and terminals on bottom.
