I have a 1996 ezgo textron series system golf cart. When using a testing procedure to test the speed controler should the motor run when pushing the pedal after applying the jumper wire on the B+ termal and the two red wires on the solenoid ? Im asking because as long as the jumper wire is there the cart runs fine wheather the key is off or on. Am I missing something???
