1996 CC regen
HOOD 1
1996 regen cart the brake is activating all the time. Changed Sol. and still same thing. Can't you disable this by cutting one of the wires from the motor?
Look on the motor for a 3 wire plug connector. On certain years if you cut the green wire there it will eliminate the regen braking. I forget what years this works on so do this at your own risk or wait for someone else to confirm. If you cut the green wire leave enough wire on both ends to reconnect the wire if it doesn't work out.
shadowman
yes green wire should disable brake but if you have a problem thats not gonna help there has to be a reason it keeps activating.......is it on and off or does it stay engaged?....................
