1995 G14A Died Going Up a Hill and Won't Start
dsilverback
HELP
I have a G14A and was using it. Went to go up a hill and would not go all the way up. Rolled down the hill and now will not start no clicking sounds nothing
Any suggestions?
djlan99
Thats the best one I have heard yet!
If it was a hill in the woods I would check the wires underneath the cart.
Does your reverse buzzer come on?
Check cables to the solenoid and battery also fuses.
Check for ground to engine.
These 4 cycle carts never climbed a hill very well even when the secondary clutch was wound
properly.
dsilverback
Thanks
I unhooked the battery then reconnected it and it started running. I not sure what happened. As best as I can tell the battery shifted and pulled on the battery cables, causing them to not make a good contact
