According to my notes, checking the resistance across the coil of the ITPS reads about 2.7 meg ohms (not connected to anything). I know that sounds high, and some cheap DVMs won't even read that high of a resistance measurement, but that is what I have in my notes. I will check it again tomorrow, I have new one over at my shop, and let you know if I made a mistake. Another way to test it is to simply check the voltages at its contacts as you move the core from its resting position to full throttle. One contact will show between 12 and 15 volts (the supply energy to the ITPS) and the other should vary from about .5 volts (slow speed ) to 1.5 volts (fast speed ).
