Hello Dan. Finally I found someone who is more open minded about parts interchangeabilty. To start with, G2 and G9 belong to the same family and practically all parts are interchangeable. What you see as difference is purely cosmetic. Different roof pillar, different A-arms (buy you can interchange). That's it.
The G8 uses a different ignitor and of course a different wiring harness to fit the ignitor male and female plugs. All other parts are interchangeable from carburator to shift cables to accel and governor cables, etc.
The G14 is somewhat similar (except for the body style which is more like a G16). You can transplant a G2 engine to a G14.
Ignitors between cart models and even cross models (i.e., ClubCar, Hyundai and Ezgo and Melex) are also interchageable depending on your "knowledge" of electricity. Some Ezgo ignitors (very cheap in used condition) can be wired such that you can use them in your G2, G9, G8, G11 and G14. The problem with Yamaha ignitors is that if the connectors (male and female plug) are damaged, you have to buy a new wire harness or a new female plug if you can find one.
The EZGO ignitor has only 5 wires and that is all you need really (please refer to an EZGO wiring diagram). The Yamaha ignitors come with 7 pins and 9 pins. I find the extra 2 and 4 pins (representing wires) irrelevant for my needs. Example: the buzzer wire need not pass through the ignitor.
The other nice thing about EZGO and Hyundai (same ignitor for certain models) ignitor is that you can splice the wires in case you have a problem with a wire or two.
I have a Melex with an EZGO solenoid and a Hyundai ignitor. My G2 is running on an EZGO solenoid and EZGO ignitor. The ignition coil came from a Japanese Yamaha G10 (yes G10, Turf Lady that's what they call the model in Japan).
The possibilities of part swapping is endless.
