1989 EZGO Marathon Clutch Removal Problem
big mack
Trying to remove drive clutch using the right puller. Have used tire shop high torque impact wrench and can't break it loose. Can anyone give me some ideas to try? I am sure it has never been removed don't want to damage clutch still works fine. A lot of time spent just to install a $5 seal.
big mack
Thanks I have tried that and it still won't brake loose. The seal shows no sign of leaking I had the jug bored out and new piston. I think I will put it back together and see how it runs
Tom M.
Last week we had to remove the drive clutch on our EZGO, we used the oil in the hole trick with the 3/4" /16 bolt, it worked perfectly!!!
