1988 trouble - late start
shootingpaul
hello,
I got this 88 ezego in no working condition, rebuild engine, runs but have some issues
#1 it takes about 5-6 seconds for it to start;
#2 it has no power to go up hill, runs great on the flats
pls help
Welcome
did you replace the crank seals with the rebuild? are you sure the clutches are shifting.
shootingpaul
yes that how it started - replace crank seals, then your crank has a play etc - so I said just rebuild the engine while you have it apart anyway
I do not understand what you mean by clutches shifting, it goes forwards and backwards, seems like better back than forward
shootingpaul
I cleaned and adjusted carb, runs better, found that the power issue is that both clutches are worn out, do you know were I can get new clutches for 88 ezego for a good price?
thanks
