Pulled the motor today,found head gasket blown. going to replace crank seals while I had it out.Looks like I need a puller bolt for the clutch side,The fly wheel side,I removed the 6 bolts holding the flywheel on and marked the center piece and removed 2 screws,not sure how to remove center plate and wheel to replace crank seal.
