1983 CC 36V wiring help
Having a few problems with wiring details. What connects to the F & R switch and charger receptacle
diagram on this site only shows 4 mirco switches I have 5 in my speed switch box (attached what diagrams I am using)
My question is from key switch where does it connect on the F&R switch drivers side or pass side or to a solid post (s1 cable is connected to) or directly to battery
Out of the speed switch box I have one wire (18) what part of the F&R switch dose it connect to
Thanks Matt
shadowman
you should have 5 microswitches, 1 is the main the other 4 are speeds to activate speed solenoids......if your looking at the cart from the front the wire should bolt on drivers side.........as to one going to a battery it goes to the same battery that has the charge recptical wire mounted, i beleive drivers side front neg. terminal.....................................
shadowman
if you can try and confirm about the wire going to the battery i,m not 100% certain on that one...................................
