Cisgww
1981 Yamaha G1-A2 starter generator play in mounting? I had read somewhere that a worn mounting bolt or tube under the starter generator could cause noise.
With belt and tensioner removed I can move the entire starter generator assembly a bit and find play in the bolt and tube where mounted to the frame.
However, since the starter generator is always pressed away from the engine by the tensioner assembly to keep a tight belt, wouldn't this play be acceptable and only detected when tension is released and belt removed?
Could this be a source of any elusive noise? Does the tube and bolt need replacing? If so, does anyone know a source for the tube and bolt?
Please check out this video.
www.dropbox.com
Yamaha G1-A2 Golf Cart rebuild- WHAT IS THAT NOISE starter generator mount movement IMG 1052-4.mov
Shared with Dropbox
