1973 Taylor Dunn Battery Charger
Xirxious
I’ve tried the $60 battery chargers off eBay and they seem to shut off almost immediately. I’m going to check the wiring diagram tonight. What Charger should I order to get the batteries fully charged? I’m having trouble finding an original Taylor Dunn charger.
Zman
A 16 amp Lester summit charger is good enough. You can also install your cord into it for on board or stand alone . This charger will do either 36 or 48 volts. I guess you need the 1050 Watt . the 650 watt is only 13 amps
