168 VOLT/1000AMP CLUB CAR
dice23
HEY IF ANYBODY IS INTERESTED,I WILL BE SELLING MY NEWLY BUILT CART. IT HAS 168 VOLTS OF SVR BATTERIES AND A 1000AMP LOGISYSTEMS CONTROLLER WITH A D&D MOTOR WITH A TWIST. THIS IS THE PACKAGE THAT I SET THE 144 VOLT DRAGBIKE RECORD WITH THIS YEAR! IT WILL DRAG THE SPRING PERCHES FOR OVER 100 YARDS @ 50MPH! GPS SAYS 58MPH WITH STOCK GEAR RATIO. I DON'T HAVE ROOM FOR THIS AND MOST TRACKS WILL NOT LET ME RUN IT. I HAVE A ELECTRIC PRO STOCK DRAGBIKE CALLED THE PREDATOR THAT RUNS 11'S (SOON TO BE IN THE 9'S) I NEED MONEY TO STEP UP A BIT AND THIS CART HAS TO GO. MY FACEBOOK PAGE IS JEFF DISINGER OR SKIN FUNK TATTOO. I HAVE SOME VIDEO OF THIS BEAST ON THERE. MY UTUBE CHANNEL IS JEFFDISINGER. I DONT BUILD SLOW OR JUNK VEHICLES. IF YOU WAN'T A FAST CART HERE YOU GO! FEEL FREE TO CALL 315-727-2699 JEFF
Pimp Daddy
Dice....Went on FaceBook and watched the videos....Great wheelies!!! Got one question...You are running 168 Volts....and the TOP speed is only 58 mph??
Pimp Daddy
Just figured with the 168 volts, D&D motor, and the 1000 amp controller... Even with stock gears.... Don't get me wrong...It hauls A$$....But not what I'd expect with all that...
dougmcp
Motor and controller size is almost irrelevant, with 8:1 gears, 20.5" tires and a motor spinning at 8000 rpm, the max speed is 60mph. The only way to get it any faster is 6:1 gears or larger tires, motors blow up after 8000.
