1206 controller help
ExtremeCarts
I am having trouble finding the schematic for the 1206 controller 3 terminal so i can rewire my cart to work with it i had a four terminal but it burned up any help would be great thanks
Welcome to the forum.
The newer stock and aftermarket EZGO controllers don't have a A2 on the controller. If the old controller has 2 cables connected to A2 you can remove them from the controller and bolt them together or make a new cable. Making a new cable is the best way. If you do bolt the two cables together make sure you tape the connection real good so it doesn't short out on anything.
