i am new to the forum, and i did try to search past posts as to avoid redundancy, but i still have a few questions. i have an 07 pds with the freedom plug, and May 09 batteries. every connection seems to be clean as can be, water levels are fine, and after taking off controller cover, there is not even a speck of dust on it--looks like new. i have had three different people check batteries and charger and say that they are fine. it has a battery meter on dash and in the past we could always play 27 holes and still show 3/4 full on the meter. now after 5 or 6 holes it is at 3/4 and the cart will barely make 12 holes.
on a full charge it will throw your head back at WOT, but after a couple of holes the take off power is gone, and you can not go up a steep hill. the puzzling part to me is that although you can't go up a hill after a few holes, you still have close to full top end speed when you are on a flat or downhill cart path. other carts that had low batteries would barely creep in to the clubhouse.
i would appreciate any and all advice. thanks
