03 CC 48V
cpatterson
Just installed a new state of charge meter today. All went well with install. Hooked up battery cables turned key, and meter lit up. Went to hit gas to move cart and light on charge meter dimmed, and cart wouldnt move. So I unhooked new meter and still nothing happens. I hear the click of the solenoid when pedal is pushed down. Checked all battery cables for tight connections also. Thanks for any help.
I see you can reset the controller, but what I have found is for a regan. I dont believe I have a regan cause I dont have a tow/run switch. Or am I wrong??
Double check your connection and make sure you didn't crass a battery cable. If the cart ran before you added the meter chances are something is wired wrong.
