02 ezgo problem
crazygo
I have an 02 ezgo txt. I have just replaced the solenoid and fwd/rev switch but still wont engage the motor. The "C" wire on the fwd/rev switch that goes to the "A2" lug on the motor has no voltage. Can anybody help with this.
Bass Hole
Does the solenoid click when you press the pedal? Does the reverse alarm work when you put the switch in reverse? What is the location of your forward and reverse switch dash or kick panel?
