Hi,
I have an issue I have never dealt with before. I took an 01 gas cart apart and pressure washed everything. I put it back together and took it for it's first ride. Got about a block down the road and the thing is fast so I assume someone has at least adjusted the governor. When I let off the gas pedal and came to a stop I heard the starter still turning over. Pressed the gas pedal and it started and I drove it back to the shop. When I got there it was still turning over. I grabbed a wrench to take off a battery cable but before I did it stopped turning over. I started it again and stopped and again it kept turning over. I assume it's an adjustment or something gummed up causing it to continue turning over.
Any insight on what to try would be appreciated. Thanx guys!
