Cartaholics.com - The Golf Cart Forum for the Cart Enthusiast. Golf Cart Repairs, Golf Cart Troubleshooting, Golf Cart Wiring Diagrams, Golf Cart Manuals, Golf Cart FAQ, Golf Cart Reviews, Golf Cart Parts, Golf Cart Accessories, Golf Cart Lift Kits, Custom Golf Carts, etc.
Cartaholics on Facebook
Home
Mission
Forum
Rules
Golf Cart Events
Members Carts
Links
CAH on Facebook
Allsports Golf Cart Lift Kits and Golf Cart Accessories - Made in the USA
Everything Carts - Golf Cart Parts, Golf Cart Accessories
BuggiesUnlimited - Golf Cart Parts and Golf Cart Accessories,
Search
Members
Calendar
Help
User CP
New Posts
My Assistant
  Reply to this topicStart new topic
ftfixer
Posted: January 29, 2012 - 07:22 PM
Quote Post
Group: Members
dudley,ga
:tip: been a while since i made any post and i need some help. i just did a ring and valve job on my 295 robins and got it back running it runs good but after driving around for a while i noticed an oil leak that seems to be on the clutch side of engine oil was all over the starter and front of engine. it did not seem to be leaking from the cam shaft seal possibly the balancer but it seems to be running down the front of engine. any help will be appreciated i'm sure i will probably have to pull the engine again. :usaflag1:
PMEmail Poster
Posted: January 29, 2012 - 07:44 PM
Quote Post
Group: Members
Waldo Wisconsin
are ya sure theres not a crack in the breather hose.
PMEmail PosterAOL
ftfixer
Posted: January 29, 2012 - 08:20 PM
Quote Post
Group: Members
dudley,ga
:tip: could be i didn't notice 1 when i put it back together i'll check it out in the morning. :usaflag1:
PMEmail Poster
ftfixer
Posted: February 3, 2012 - 10:56 PM
Quote Post
Group: Members
dudley,ga
:tip: hose from crankcase is in good condition how much oil would leak from the head gasket if not torqued correctly. . no seals are leaking what about the small o-ring between the block and plate behind flywheel if left out will this cause any problems there are no visible leaks there either. i'm just stumped on this my first rebuild. :dazed:
PMEmail Poster
Posted: February 3, 2012 - 11:12 PM
Quote Post
Group: Members
Waldo Wisconsin
its hard to say where the leak is then, the cam cover or the plug that pushes into the head where the rocker shaft goes into. cracked valve cover :dazed: think ya may need to pull the fan shroud and have a look :twocents:
PMEmail PosterAOL
Posted: February 3, 2012 - 11:13 PM
Quote Post
Group: Members
Waldo Wisconsin
if the head was loose enough for oil to leak out so would the compression.
PMEmail PosterAOL
ftfixer
Posted: February 5, 2012 - 07:33 PM
Quote Post
Group: Members
dudley,ga
:thumbsup: nubs you were correct it was the plug on the rocker shaft i did not even think about putting it back in didn't even need to remove it. the cart is running good with no oil leaks and i realy do appreciate the help. :usaflag1:
This post has been edited by ftfixer on February 5, 2012 - 07:35 PM
PMEmail Poster
Posted: February 5, 2012 - 07:50 PM
Quote Post
Group: Members
Waldo Wisconsin
Cool :thumbsup:
its easy to over look, t'il ya over look it once. a fella won't do'er again.
PMEmail PosterAOL
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
Topic Options Reply to this topicStart new topic
LoFi Version
Cartaholics.com - The Golf Cart Forum for the Cart Enthusiast. Golf Cart Repair, Golf Cart Troubleshooting, Golf Cart Wiring Diagrams, Golf Cart Manuals, Golf Cart FAQ, Golf Cart Reviews, Golf Cart Parts, Golf Cart Accessories, Golf Cart Lift Kits, Custom Golf Carts, etc.
Cartaholics
2005-2017 HotRodCarts LLC
All Rights Reserved
No part of this web site may be reproduced in any way
or by any means, without the prior written permission of HotRodCarts LLC
